Find solution of eqation 2cot^2x-5cosec x =1
  • Thread starter Thread starter vkash
vkash
2cot2(x)-5cosec(x)=1 for exactly 6 values of x belongs to [0,nπ], then find the minimum value of n.
my answer is 5.
How i did it.changing cot to cosec and then solving equation it will give something like cosec(x)=3. for x belongs to 0 to 5π it has 6 solutions..
this is question of a class test & answer in test's answer sheet is 6.
WHO IS correct. me or answer sheet??
In 2π, you'd get 2 solutions A and 180-A. So for the next 2π, you'd have 4 in total and then in 2π again, you'd get 6.
So your range would be 6π.
rock.freak667 said:
In 2π, you'd get 2 solutions A and 180-A.[/color] So for the next 2π, you'd have 4 in total and then in 2π again, you'd get 6.
If i have got A and 180-A then i have got solutions in [0,π] not [0,2π] and in next 2π(or in [0,3π]) i will have 4 solution why i should go for 4π. similarly for next 5π.
You are correct for the problem that was given.
There are two roots in [0, π] ,
two roots in [2π, 3π] ,
and two roots in [4π, 5π] .
thanks sammy..
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
