Find the normalisation constant using a trial wavefunction
martinhiggs
a particle of mass m, confined to a one dimensional infinite potential of
0\leqx\leq1 V(x) = 0
elsewhere V(x) = \infty
Choose as a trial wavefunction
\Psi(x) = Nx[1 - \alphax + (\alpha - 1)x^{2}]
Verify that
N^{2} = \frac{K}{16 - 11\alpha + 2\alpha^{2}}
1 = <\Psi|\Psi>
1 = \int^{1}_{0}Nx[1 - \alphax + (\alpha - 1)x^{2}] Nx[1 - \alphax + (\alpha - 1)x^{2}] dx
1 = N^{2} \int^{1}_{0} x^{2}[1 - \alphax + (\alpha - 1)x^{2}]^{2}
Is this right so far?? I'm not sure how to carry on. Should I expand the brackets??
0\leq x \leq 1, V(x)=0
elsewhere V(x)=\infty
\Psi(x) = Nx(1 - \alpha x + (\alpha - 1)x^{2})
Verify that
1 = \langle\Psi|\Psi\rangle
1 = \int^{1}_{0}Nx(1 - \alpha x + (\alpha - 1)x^2)\cdot Nx(1 - \alpha x + (\alpha - 1)x^{2}) \,dx
1 = N^{2}\int^{1}_{0} x^{2}(1 - \alpha x + (\alpha - 1)x^{2})^{2}\,dx
Yes and Yes. Well, you could possibly integrate it as is, but it'd be easier to see after expanding the parenthesis.
PS: Rather than typing {tex}code{/tex} for every variable, just write the whole thing in tex, it'll look a bit nicer.
When I expand the brackets and multiply by x^2
I get the following:
x^{6} + x^{2} + 2 \alpha^{2} - \alpha^{4} - 2 \alpha x^{3} + \alpha^{2}x^{4} - \alpha x^{5}
This seems totally wrong when I look at what I am supposed to get for N^2...
I think you expanded incorrectly. You should get
<br /> \left(\alpha-1\right)^2x^6-2\alpha(\alpha-1)x^5+2(\alpha-1)x^4+\alpha^2x^4-2\alpha x^3+x^2<br />
When you integrate this over the range 0 to 1, you should get the answer.
If it helps see a little bit more clearly, K=210. Not sure why your question put K rather than 210, but it is what it is.
Also, you could fully expand what I wrote down and then integrate, but you'll have a few extra terms to work with; it's usually easier to expand and regroup after integration.
Ah, excellent! Thank you SO much for your help! :)
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
