Find the second derivative of F (x)
~Sam~
Assuming sufficient differentiability, find second derivative of F(x) = integ[a,x] (t-x)2 f(t) d(t)
Probably Fund.Thm of Calculus and some properties
I really have no idea..I tried evaluating but with t=x but I get zero..I have never done second derivative so I'm somewhat clueless. Anyone care to help and explain?
The second derivative is the derivative of the first derivative. E.g., if f(x) = x^2, f'(x) = 2x, and f''(x) = d/dx(f'(x)) = d/dx(2x) = 2.
The Fundamental Theorem of Calculus can help you get F'(x), so take a careful look at this theorem and any examples that show how to use it. After that, just take the derivative of what you got for F'(x).
Use the Leibniz integral rule twice. Besides the term that you found equal to zero, there's another term that involves differentiating the integrand. That part is not necessarily zero.
I don't quite understand? I've never learned the leibniz rule. Can you exemplify it with this question? The f(t) part also confuses me.
Don't worry about the f(t) part. Your answer will be in terms of f(t). http://en.wikipedia.org/wiki/Leibniz_integral_rule Here's an easy example. Take F(x) to be the integral from a to x of x*t*dt. You only have to deal with the first and third terms in the rule. The first term you get just from putting t=x in the integrand, so x^2. That's the one you know. The last term says you should differentiate inside the integral. That gives you the integral from a to x of t*dt. Or x^2/2-t^2/2. Adding the two you get F'(x)=3*x^2/2-a^2/2. Compare that with what you get by actually integrating and then differentiating. Now try doing that with your example. What's F'(x)?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
