Find the voltage V in the circuit
The discussion revolves around finding the voltage V in a given circuit, with participants exploring various methods to simplify the circuit and calculate the voltage. The conversation includes aspects of homework-related problem-solving and circuit analysis techniques.
- Homework-related
- Technical explanation
- Debate/contested
- One participant notes the presence of a 24 volt source and states that components in parallel share the same voltage, suggesting that 24 volts will appear across the 12 ohm resistors.
- Another participant expresses frustration that their professor prohibits the use of Kirchhoff's laws, which complicates their ability to solve the problem quickly.
- A suggestion is made to redraw the circuit to clarify the arrangement of components, recommending the use of the voltage divider equation.
- One participant proposes simplifying the circuit by reducing four resistors to two and computing the equivalent resistance of the series and parallel arrangements.
- There is a discussion about the parallel nature of the 6 ohm and 12 ohm resistors, with one participant asserting they share common nodes, while another challenges the initial claim about voltage distribution across the resistors.
- A later reply emphasizes the importance of redrawing the circuit to reveal familiar patterns and suggests that Thevenin equivalents could simplify the analysis without using Kirchhoff's laws.
- Participants discuss the need for current calculations to determine voltage drops across components, indicating a more complex approach may be necessary given the constraints on analysis methods.
Participants express differing views on the application of circuit analysis techniques, particularly regarding the use of Kirchhoff's laws and the interpretation of voltage across the resistors. There is no consensus on the best approach to solve the problem, and multiple competing views remain.
Participants mention limitations imposed by the professor's instructions, which restrict the use of certain analysis methods. There are also unresolved discussions about the correct interpretation of the circuit configuration and voltage distribution.
- · Replies 2 ·
- · Replies 5 ·
- · Replies 1 ·
- · Replies 15 ·
- · Replies 15 ·
- · Replies 26 ·
- · Replies 8 ·
- · Replies 3 ·
- · Replies 5 ·
