Find the x component of the Electric Field
To find the x component of the electric field when charge density varies with x, the Poisson equation is used, leading to the expression dE_x/dx = p(x)/ε₀. The integration of this equation yields E_x(x) = (1/ε₀)P(x) + c, where P(x) is the integral of p(x). Since boundary conditions are not specified, it's common to assume E_x approaches zero as x approaches negative infinity or to use a specific point to determine the constant of integration. The chosen boundary condition at x=0, where E_x=0, leads to c being calculated as -P(0)/ε₀. This approach is deemed correct given the lack of additional boundary information.
themagiciant95
Find the general formula for the x component of the electric
field if the charge density p varies only with x throughout all
space.
I started using the poisson equation \bigtriangledown \bullet \bar{E} = \frac{p}{\varepsilon_{0}}
From the problem text, I know that p has only the x component and so also E has only the x component.
With these information, i tried to calculate the poisson equation, obtaining :
\frac{\partial E_{x}}{\partial x} =\frac{p(x)}{\varepsilon_{0}}
But, i don't know how to continue the calculations... Can you help me ?
Likes Delta2
Since the variation is only in x, the left hand side is \frac{dE_x}{dx}, not \frac{\partial E_x}{\partial x}. Now multiply through by dx and integrate both sides.
Likes Delta2
Do i have to integrate it as an definite or indefinite integral ? In the latter case, how can i manage the constant of integration ? Thanks
Well, since you aren't told the boundary conditions, you will have to make some assumptions. You could assume for example that Ex at -∞ is zero. Or you could include the value of Ex at some point in your calculation.
For example, if i include the value of Ex in a point (it's sufficient ?), how can i use this value to calculate the constant of integration ? Thanks again
Why don't you show us the calculation with the constant of integration included? Then if it isn't clear how to deal with it we can make suggestions.
<br /> \int dE_{x} =\frac{1}{\varepsilon _{0}}\int p(x)dx<br />
E_{x}(x)=\frac{1}{\varepsilon _{0}}P(x) + c
As boundary i chose:
x=0 \rightarrow E_{x}=0
so
c=-\frac{1}{\epsilon _{0}}P(0)
is this correct ? Thanks
up
It looks OK to me. Without knowing more about the boundary conditions, I think something like this is the best you can do. You could try asking your teacher for more clarification.
Likes themagiciant95
Thanks so much for your help :)
