Finding acceleration when given coefficients
To find the acceleration of a 7.0 kg block subjected to a 10 N force with a coefficient of friction of 0.45, it's essential to calculate the frictional force first. The weight of the block is 70 N, leading to a frictional force of 31.5 N. Since the applied force of 10 N is less than the frictional force, the block does not move and experiences deceleration. The net force acting on the block is 21.5 N in the opposite direction, resulting in an acceleration of -3.04 m/s². The discussion highlights the importance of understanding static friction in determining whether an object can start moving.
nic.harv
what will be the rate of acceleration be when a 10N force is applied to a 7.0kg block of wood resting on a table with a coefficient of friction equalling 0.45?
ok so i am totally confused, I am thinking i have to use 2 formulas but I am not exactly sure
i tried the formula:
Fn = Fg = mg
and did:
Fn = 10(7.0) = 70N
then i thought:
Fκ = μ Fn
so i did:
Fκ = (0.45)(70) = 31.5m/s(squared)
im not sure if that's right it doesn't seem to be please help!
If the force of friction exceeds the applied force the object can not start to move, can it? It is static friction that acts on an object in rest. The static friction is less than or equal to μ Fn: Fs≤μ Fn. Only when the applied force exceeds the maximum value of the static friction, can the object accelerate in the direction of the applied force.
ehild
You have taken g = 10 N/kg... that is OK, so the weight of your block is 70N which gives a friction force of 0.45 x 70 = 31.5N (this is not an acceleration).
The applied force on the object is 10N which is less than the friction force. This indicates that the object is decellerating (-acceleration)
The resultant force is 31.5 - 10 = 21.5N and therefore the acceleration/decelleration is
a = F/m = 21.5/7 = 3.04 ms^-2
Should really be written as -3.04 ms^-2
PS
The wording of the question is not great...'resting on a table'... suggests not moving but the numbers do not support that !
Where did the question come from.
thanks guys! it was on one of the practice tests that my teacher wrote out for us, this helped alot! :)
