Finding charge, voltage and resistance
The discussion revolves around calculating charge, voltage, and resistance related to a heart defibrillator's operation. To find the charge (Q), the equation Q = I × t can be used, where I is the current (12A) and t is the time (3E-3 seconds). For voltage, the energy (300J) can be related to voltage using the formula E = V × Q, allowing the calculation of voltage once charge is determined. Resistance can be found using Ohm's Law, V = I × R, after calculating voltage. Understanding these relationships is crucial for solving the problems presented.
Kathi201
A heart defibrillato passes a 12A current through a patient's torso for 3E-3 seconds to restore it to normal beating.
a. How much charge passed through the patient's body?
b. What voltage was used if a total energy of 300J was dissipated? by the current
c. What was the resistance of the path through the person?
For a I know that the current is I and I have the time and I need to figure out Q but I do not have any equations that have all three of those variables in it so I am stuck on what equation to even start with.
For b I am struggling with the same problem. I know that Voltage is equal to the current x resistance but I do not know where the energy comes into place
I know the resistance is the resistivity/A is A the area? How would I figure that out then?
Any help would be appreciated!
Hi Kathi201,
What is the definition of current?
What quantity can you find from knowing the energy and the time? How is that related to voltage?
Once you find the voltage in part b, what is the relationship between voltage and resistance?
