Finding derivative of Trig. Functions
DTA
h(x) = (sin2x)(cos2x)
I attempted to use the product rule:
(sin2x)(-sin2x)+(cos2x)(cos2x) = cos22x-sin22x
The book has the answer at 2cos4x, which I obviously didn't get. I've retraced my steps and while unsure of trig. functions, cannot find where I made my error.
You have forgotten the chain rule when you did the product rule. The derivative of cos(2x) will be -2sin(2x) [Note the 2 in front, from the chain rule].
Other than that, your answer is the same as the book, based on the identity that cos(2u)=cos^2(u)-sin^2(u)
(Alternatively you could have used the double angle formula for sin to rewrite your original function, and then found the derivative)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
