Finding electric potential given a cylindrical configuration
To find the electric potential between two concentric cylinders, start by applying Gauss's Law to determine the electric field E in the region between the cylinders. The relationship between electric field and potential is crucial, as E can be expressed in terms of charge and area. The electric field can be derived as E = λ/(2πεr) for a cylindrical configuration, where λ is the linear charge density. The potential difference can then be calculated using the integral of E, leading to the form V(r) = constant1 - constant2 ln(r). Understanding the Gaussian surface and charge enclosed is essential for accurate calculations.
carloz
You have two concentric cylinders. The inner cylinder has radius a and the external cylinder has radius b. Find the electric potential in the region between the cylinders.
[Hint: The final equation takes the form V(r) = constant1 - constant2 ln(something) ]
I think:
Gauss's law: \Phi=EA=q/ε
Coulomb's law: E=q/(4πεr^2)
I really don't know.
Start by finding the electric field E between the two cylinders using Gauss's Law.
How is E related to the potential?
Okay
So
EA=q/ε
E=q/(εA)
A=2πrL
dA=2πLdr
dE=q/(ε2πLdr)
E = ∫(limits a and b) q/(ε2πLdr) = q/(ε2πL) ∫(limits a and b) 1/dr
Am I on the right track? If so, how to evaluate ∫(1/dr) ?
Thank you.
Do you know the answer to this? I am just learning this material also, so I don't know if I am thinking through it correctly. But the outer shell should be irrelevant as the electric field is going to be zero for any point inside it assuming it is infinitely long, correct? For the electric field at r distance from the center of cylinder with radius a, would its magnitude be λ/(2πεr) (derived with Gauss's law)? If so, you would end up with Δv(r) = v(r) (taking v_i = 0) = λln(a)/(2πε) - λln(r)/(2πε) where a <= r <= b, λ = q/l. But I have no idea if that is correct.
carloz said:
Okay
So
EA=q/ε
E=q/(εA)
A=2πrL
dA=2πLdr
dE=q/(ε2πLdr)
Thank you.
No. First off, what's your Gaussian surface and what expression is equal to the amount of charge enclosed in it?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
