Finding final Velocity given mass, force, and displacement
To find the final velocity of a 2.78 kg block pulled by a 15.8 N force on a horizontal surface with a coefficient of kinetic friction of 0.106, the work done must be calculated first. The work is determined using the formula W = Fx * Δx, yielding a value of 45.504 N m. The final velocity can then be calculated using the equation Vf = sqrt((2*W)/m). It's essential to consider the net force, which accounts for friction, when calculating the work done. The discussion emphasizes the importance of using the correct values and formulas to arrive at the final velocity.
Bearbull24.5
2.78 kg block is pulled (from rest) by a force (horizontal surface) of 15.8 N. The coefficient of kinetic friction is .106. What is the velocity after 2.88 m?
fk=N(uk)
Vf=sqrt((2*W)/m
I attempted to find the final velocity by first finding the work (w=Fx*deltax) and then plugging it into the Vf equation I have listed.
Hi Bearbull24.5! :smile:
(have a mu: µ and a square-root: √ and a delta: ∆ :wink:)
Bearbull24.5 said:
fk=N(uk)
Vf=sqrt((2*W)/m
That should be ok (assuming that m is inside the bracket). :confused:
What figures did you get?
I got 5.7 for the final velocity and a work of 45.504 N m
Do I need to use the coefficient of kinetic friction for anything?
Bearbull24.5 said:
I got … work of 45.504 N m
No, you need to use the net force. :wink:
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
