Minimum Force for Moving a Sled on a Horizontal Surface
  • Thread starter Thread starter tutojean
    Force Minimum
To determine the minimum force required to keep a sled moving on a horizontal surface with a kinetic friction coefficient of 0.20 and a mass of 2 slugs, the frictional force is calculated using the formula fs = μs(N), where N is the normal force. The normal force for a sled on a flat surface is equal to the weight, which can be calculated as mass times gravity (2 slugs x 32 ft/s²). This results in a frictional force of 12.8 pounds. The discussion also clarifies that the unit of force is in pounds when using slugs. Understanding these calculations is essential for solving similar physics problems.
tutojean
A sled is pulled over a horizontal surface where the kinetic coefficient of friction is .20. What is the minimum force necessary to keep the sled moving if its mass is 2 slugs?
fs = Ns(mg)
fs = (.20) (2 slugs) (32)
=12.8
This problem has got me stumped. Please help! Thank You.
What is the unit of fs?
I assume 12.8 N
tutojean said:
I assume 12.8 N
Unit force is N if mass is in kg.
