Finding resonance frequency of non ideal inductor
The discussion focuses on finding the resonance frequency of a non-ideal RLC circuit, specifically analyzing the transfer function H(jω) derived from the circuit configuration. The expression for H(jω) is given as H(jω) = jωRC / (1 + jω(R + RL)C - ω²LC). The resonance frequency can be calculated by simplifying this expression and determining when the denominator approaches zero. The conversation emphasizes the importance of correctly defining the total resistance and suggests reviewing standard RLC circuit resonance calculations for clarity.
  • Understanding of RLC circuit theory
  • Familiarity with complex impedance and transfer functions
  • Knowledge of Bode plots and resonance frequency concepts
  • Experience with circuit analysis techniques
  • Review standard RLC circuit resonance calculations
  • Learn about complex impedance in RLC circuits
  • Study Bode plot representation of transfer functions
  • Explore the implications of non-ideal components in circuit analysis
Electrical engineers, circuit designers, and students studying RLC circuits and resonance phenomena will benefit from this discussion.
Gauss M.D.
We have this circuit:
(uin+)---[1/jωC]--[jωL]--[RL]----o------uout+
(resistor of value R connecting the two lines at their o's here)
(uin+)-------------------------o------uout-
Find an expression for the quotient of u(in)/u(out), and then find the resonance frequency.
Uout/Uin = R/(R+RL + jωL + 1/(jωC)) = jωRC/(jωC(R + RL2CL + 1)
Without the added resistance at the inductor, the resonance is 1/√LC but the expression I get when trying to find when this denominator goes to zero is just extremely sticky. Have I done something wrong or is this to be expected?
I'm afraid to say that the title is a bit misleading, since your actual problem is finding the resonance frequency of an ideal circuit for which you have the expression of [itex]H(j \omega)[/itex]. The fact that you started with a non-ideal inductor, a non-ideal capacitor or "non-ideal anything" (for that matter) doesn't anymore have a role to play in your equations.
I didn't precisely understand your schematic (can you find a picture of it?), thus I will have to assume that you got the right expression for [itex]H(j \omega)[/itex] (but see below). If so, then you are dealing with a variation of the standard RLC circuit. I strongly suggest you to go back to your textbooks and see how the resonance frequency for RLC was calculated - it is almost exactly the same here! The calculations aren't actually harder, if you carefully deal with them. However, it seems to me you made some mistake in writing [itex]H(j \omega)[/itex] (assuming you got right the first expression). Defining [itex]R_{tot} = R+R_L[/itex], you should get:
[tex]H(j \omega) = \frac{j\omega RC}{1+j\omega R_{tot} C -\omega^2 LC}[/tex]
Now, it is customary to simplify this expression further by explicitly writing it in Bode form. In other words, you write it as:
[tex]H(j \omega)=\frac{j2\zeta' \frac{\omega}{\omega_0}}{1+j2\zeta \frac{\omega}{\omega_0} - \frac{\omega^2}{\omega_0^2}}[/tex]
where [itex]\zeta' , \zeta , \omega_0[/itex] are all known. At this point, we are half-way. Now, we must consider: [itex]|H(j \omega)|[/itex] (question: can we, instead, consider [itex]|H(j \omega)|^2[/itex] to simplify things? If so, why?). To calculate it, I suggest you to use: [itex]x=\frac{\omega^2}{\omega_0^2}[/itex] and do all the math with respect to [itex]x[/itex]. Stated this way, you should be able to conclude it.
  • · Replies 21 ·
  • · Replies 40 ·
