Calculating Take-Off Velocity for High Jumper Kwaku Boateng
  • Thread starter x2017
  • Tags
    velocity
In summary, Kwaku Boateng, a former Canadian Olympic high jumper, has a mass of 79.1 kg and experiences an average vertical ground reaction force of 1959.6 N for 0.20 s during the upward phase of his jump. Using the equation ΣFΔt=mΔv, his take-off velocity is calculated to be 2.99 m/s. The correct answer should include the force of gravity.
x2017
84
Kwaku Boateng is a former Canadian Olympic high jumper. If an average vertical ground reaction force of 1959.6 N acted on Kwaku's foot for 0.20 s during the upward phase of his jump, and Boateng's mass is 79.1 kg, what would his take-off velocity be?
ΣFΔt=mΔv
I tried it twice...
Attempt 1:
ΣFΔt=mΔv
Δv=(ΣFΔt)/m
Δv=(1959.6)(0.20)/79.1
Δv=4.95m/s
The online assignment says that this answer is incorrect.
Attempt 2:
ΣFΔt=mΔv
Vf-Vi=(ΣFΔt)/m
Vi=-[(ΣFΔt)/m]+Vf
Vi=(1959.6)(0.20)/79.1
Vi=-4.95m/s
Should I be using another equation? Or have I made a simple mistake?
Thank you in advance for your help!
Do you need to include the force of gravity?
Ahhhhh, yes that's it!
ΣFΔt=mΔv
Δv=(ΣFΔt)/m
Δv=[1959.6-(79.1)(9.81)](0.20)/79.1
Δv=2.99m/s
The computer is telling me 2.99m/s is the correct answer, thank you for your help RUber!
Likes RUber
Related to Calculating Take-Off Velocity for High Jumper Kwaku Boateng
1. How do you calculate take-off velocity?
Take-off velocity can be calculated using the formula v = √(2gh), where v is the take-off velocity, g is the acceleration due to gravity (9.8 m/s²), and h is the height of the object.
2. What factors affect take-off velocity?
The factors that affect take-off velocity include the mass of the object, the height from which it is launched, and the force applied to launch it. Air resistance and surface friction can also have an impact on the take-off velocity.
3. How does take-off velocity differ between different objects?
The take-off velocity of an object depends on its mass and the force applied to launch it. Objects with a larger mass or a greater force applied will have a higher take-off velocity compared to smaller or less forceful objects.
4. What are the units for take-off velocity?
Take-off velocity is typically measured in meters per second (m/s) or feet per second (ft/s).
5. What is the importance of finding take-off velocity?
Finding take-off velocity is important in various fields, such as physics, engineering, and sports. It allows us to understand and predict the motion of objects in flight, and can aid in designing efficient and effective launch mechanisms. In sports, knowing the take-off velocity can help athletes optimize their performance and achieve greater distances or heights in their movements.
