Finding the center of mass by integration.
To find the center of mass of a uniform semicircular disk of radius R, the solution involves using integration. The approach suggested is to divide the semicircle into thin slices of thickness dz parallel to the base. By calculating the mass of each slice and integrating over dz, one can determine the center of mass. The final result shows that the center of mass is located at a distance of 4R/(3π) from the center of the circle. This method effectively applies integration to solve the problem.
tfmfyn
Show that the center of mass of a uniform semicircular disk of radius R is at a point 4R/(3(pi)) from the center of the circle.
Total mass Center of mass = M rcm = m1r1 + m2r2 + ...
I do not know how to apply integration to this problem to find the center of mass. Help, please?
Don't you have any integral expressions for center of mass?
Hi tfmfyn! :smile:
Hint: divide the semicirce into slices of thickness dz parallel to the base, find the mass of each slice, and integrate … something … over dz. :smile:
