Finding the change in K.E. G.P.E ignored?
  • Thread starter Thread starter Icetray
    Change
The discussion revolves around calculating the change in kinetic energy (K.E.) of a crate being pulled up an incline, while also considering gravitational potential energy (G.P.E.) and friction. The key equation presented is that the total work done by all forces equals the change in kinetic energy, factoring in the work done against gravity and friction. Participants clarify that the work done against gravity is indeed related to the change in G.P.E., which should be considered in the overall energy balance. The confusion arises from understanding how K.E. and G.P.E. interact in this scenario. Ultimately, the resolution highlights the interconnectedness of these energy changes in the context of the problem.
Icetray
Hi guys! Just a little confused on the solution provided.
A crate of mass 10.0 kg is pulled up a rough incline with an initial speed of 1.50 m/s. The
pulling force is 100 N parallel to the incline, which makes an angle of 20.0° with the horizontal.
The coefficient of kinetic friction is 0.400, and the crate is pulled 5.00 m.
(d) What is the change in kinetic energy of the crate?
Change in word done = Fs - mgsin\Thetas - friction
I understand this part but I want to know why the solution key takes this change as the change in kinetic energy itself. Isn't there a gain in G.P.E. as well?
Thanks for the help!
The work done by all forces is
Fs - mgsin\Thetas - (work of friction)=ΔKE
The term -mgsin\Thetas is the work of gravity, and the opposite is the change of the gravitational potential energy, as
s*sin\Theta=h, the height reached. You can rewrite the equation as ΔKE+ΔPE=Fs+(work of friction)
ehild said:
the work done by all forces is
fs - mgsin\thetas - (work of friction)=Δke
the term -mgsin\thetas is the work of gravity, and the opposite is the change of the gravitational potential energy, as
s*sin\theta=h, the height reached. You can rewrite the equation as Δke+Δpe=fs+(work of friction)
Thanks! (: Haha I can't believe that I didn't realize that. :-X
It is a pleasure if a student feels so:smile:.
ehild
