Finding the point where the net electric field is 0
To find the point where the net electric field is zero due to three charges at the corners of an equilateral triangle, one must calculate the electric field contributions from each charge at point P, located midway between the two negative charges. The positive charge's influence must be balanced by the combined effects of the two negative charges. The electric field at point P can be expressed as a function of the distances and magnitudes of the charges, leading to the equation for the total electric field being set to zero. The discussion emphasizes the importance of considering both x and y components of the electric field, as the total electric field is a vector sum. Ultimately, the goal is to determine the correct distance above point P for a new charge to ensure the net electric force is zero.
012983
Three charges of equal magnitude q reside at the corners of an equilateral triangle of side length a. The topmost charge is positive while the charges at the bottom left and bottom right of the triangle are negative. If point P is midway between the negative charges, at what distance above point P along the +y axis must a -8q charge must be placed so that any charge located at point P experiences no net electric force? The distance from point P to the positive charge is 9 meters.
E = (kq)/r^2
No clue. I think you would find the the electrical field for one of the points and then, using that, find the x and y components of the magnitude. Then solve for 0 = sqrt{(Ex)^2 - (Ey)^2}... but the "any charge located at point P" is confusing me. Or else I'm not thinking correctly.
It just means that the electric field at P has to be 0. So assume that the third charge is a distance "a" from P, calculate the electric field at P, and set the result to 0.
If the electric field at P is equal to (-4*ke*q)/(3a^2), where ke = 8.99 * 10^9, do I proceed by plugging in -8q for q and setting equal to 0?
If so, how would I solve for a? a could be any number so long as the numerator is 0.
That's not the total electric field. There are 3 charges, not just one, and the electric field has both an x and a y component.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
