What Happens When U, Q, and W Are Negative in the First Law of Thermodynamics?
When U, Q, and W are negative in the first law of thermodynamics, it indicates that the system is losing internal energy, leading to a decrease in temperature or phase changes like freezing. A negative dU signifies energy loss from the system. If Q is negative, the system releases heat to its surroundings, while a negative W indicates that the system does negative work on its surroundings, equivalent to positive work being done on the system. The equation dU = Q - W can be rearranged to reflect these changes, emphasizing the impact of negative values on energy dynamics. Understanding these relationships is crucial for analyzing thermodynamic processes.
Sixty3
I am looking into the first law of thermodynamics.
But I'm not sure with some parts.
dU=Q-W What does it mean when U Q and W are negatives.
Also solids with W=0
So the equation will change to -U=-Q+W
Does it lose it's internal energy?
It's
dU = \delta Q - \delta W
If dU is negative that means that the system loses internal energy. The temperature goes down, or water freezing etc.
if \delta Q is negative, the system supplies heat to its surroundings.
if \delta W is negative, the system does negative work on its surroundings, this is the same as positive work done on the system
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
