Solving a Nonlinear ODE for Parachute Area in Free Fall
francisg3
We recently discussed a problem in class involving free fall and parachutes.One of the examples was to solve for the area of a parachute in drag,gravity,air density,mass and the speed at which the object deployed the parachute and the speed it hit the ground out. I'm pretty sure I know how to do the porlbem if I could only get past the first few steps. My guess is that I need to solve the following nonlinear ode:
m (dV/dt) = mg-(1/2)(air density)(drag constant)(area parachute)(V)^2
i replaced the equation with something like this to simplify it:
m (dV/dt) = mg-kV^2 where k is all those constants
now I'm familiar with seperable ode's and this is the form i obtained:
dV/dt = g-(k/m)V^2
from then on i am lost, i think i just need a bit of help onto the next step or two then i should be able to get the problem rolling. Any help or input would be greatly appreciated! Thank you.
Welcome to PF!
Hi francisg3! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
francisg3 said:
dV/dt = g-(k/m)V^2
yes, so dV/(g-(k/m)V2) = dt :wink:
And you can use partial fractions to integrate that.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
