How Do Physics Principles Determine the Outcome in Log and Elevator Scenarios?
  • Thread starter Thread starter eureka360
    Floating
The discussion revolves around two physics problems involving a log on water and an elevator. The first problem asks for the horizontal distance between a bridge and a log when a stone is dropped from a height of 75 meters, with the log moving at a constant speed of 5 meters per second. The second problem involves calculating the work done by the tension in a cable lifting a 1200-kilogram elevator over 35 meters and the work done against the elevator's weight. Key concepts highlighted include the calculation of weight as mass times gravitational acceleration and the definition of work as force multiplied by distance. Proper posting of homework problems in designated sections is also emphasized.
eureka360
hi guys.. can i ask you about this problem?
A log is floating on swiftly moving water. A stone is dropped from rest from a 75meter high bridge and lands on the log as it passes under the bridge. If the log moves with a constant speed of 5 meters per second, what is the horizontal distance between the log and the bridge when the stone is released?
A cable lifts a 1200kilogram elevator at a constant velocity for a distance of 35 meters. What is the work done by:
a.) the tension in the cable
b.)the elevators weight?
Please post homework problems in the appropriate homework sections, e.g. Introductory Physics.
Weight is nothing more than m*g, where m is mass and g is acceleration due to gravity. Work is the integral of force over distance, or simply product of force * distance, if force is constant over the distance.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
