Fluid mechanics-Total energy line of static system
In a static fluid system with two reservoirs at different elevations, the total energy line will reflect the potential energy due to elevation differences. Since the flow velocity is zero, the total energy line will start at the water level of the higher reservoir and will slope downward toward the lower reservoir, indicating a loss of potential energy. The pressure does play a role, as it contributes to the overall energy balance, but in a static scenario, the pressure difference primarily affects the height of the water column. The total energy line will not be a straight line; it will follow the slope of the pipes connecting the two reservoirs. Understanding these principles is crucial for analyzing fluid behavior in static systems.
5mmgridbok
I have two reservoirs, connected by two pipes. The first reservoir is higher in elevation than the second. If the system is full of static water, what would the total energy line look like?
Since the velocity of the flow through the system is 0, would the total energy line just be a straight line emerging from the water level of the higher reservoir and continuing parallel to the ground?
Or would it slant down due to the difference in elevation, following the slanting of the pipes? How would it end at the lower reservoir?
Thank you
You must show some work answering your own questions. PF is not a HW oracle.
I'm sorry, I was trying to explain the extent of my reasoning in the second paragraph.
I will add more.
This is the Bernoulli equation:
z + (u^2/2g) + (P/pg) = Constant.
The velocity (u) being 0 simply follows on from my attempt at answering my own question.
Would the pressure have any effect?
