Derive a flow rate equation that accounts for the fluid properties?
To derive a flow rate equation for a sphere in a fluid with viscosity and density, the discussion highlights the need to incorporate fluid properties into the standard flow rate formula Q=Av. The original equation does not account for viscosity (n) and density (p), which are crucial in determining how fluid behaves when a cavity is created. The question of fluid movement in the absence of gravity and pressure is raised, suggesting that additional forces or conditions may be necessary for flow to occur. Participants are encouraged to explore how these factors influence the velocity of fluid entering the cavity. The conversation emphasizes the complexity of fluid dynamics beyond basic equations.
brupenney
:smile:Hi
I have been wrestling with this situation for a while, trying to derive an equation for it...A sphere is placed in a fluid of viscosity n and density p, outside any gravity. The sphere is instantly beamed out (perhaps by Capt Kirk?). At what volume rate will the fluid rush into the vacant cavity, taking into account p and n? The familiar Q=Av (flow rate = Area times velocity) yeilds Q=4pi x rsquared x v, but doesn't take the other factors influencing the velocity into account.
Can anyone here derive a flow rate equation that accounts for the fluid properties?
Thanks a lot
Why would it flow at all if there is no gravity (and presumably no pressure).
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
