Checking 2B=Ф/A - Is It Correct?
  • Thread starter Thread starter Kev1n
Kev1n
1. Does this formula make sense
2B=Ф / A
3. need to check please
Hmm, it does not make sense to me. But it might, if you could explain what B, Ф, and A are, and describe the situation that this equation applies to.
