Flux due to a charge located at the corner of a cube
The discussion centers on applying Gauss' Law to calculate electric flux due to a charge located at the corner of a cube. The correct answer is B, derived from the understanding that the charge at the corner affects three faces of the cube, leading to a total flux calculation of flux = charge / (2 * epsilon). Participants clarify that Gauss' Law is applicable only when the charge is enclosed within a volume, and symmetry arguments can be applied by considering a larger cube divided into eight smaller cubes. Misinterpretations regarding the definition of "sides" and the application of symmetry in this context are also addressed.
  • Understanding of Gauss' Law and its applications
  • Familiarity with electric flux calculations
  • Knowledge of charge distribution and symmetry in electrostatics
  • Basic concepts of electric fields and their behavior near charges
  • Study the derivation and applications of Gauss' Law in electrostatics
  • Learn about electric flux and its calculation through different geometries
  • Explore symmetry arguments in electrostatics, particularly for non-spherical surfaces
  • Investigate the implications of charge placement on electric field behavior
Students of electromagnetism, physics educators, and anyone seeking to deepen their understanding of electric flux and Gauss' Law applications in complex geometries.
SmartAries
A particle with charge 5.0 micro-coulombs is placed at the corner of a cube. The total electric flux through all sides of the cube is:
A) 0
B) 7.1 * 10^4
C) 9.4 * 10^4
D) 1.4 * 10^5
E) 5.6 * 10^5
flux = q / epsilon
The correct answer is B, but I am not sure why.
I have a few confusions regarding this problem. First of all, I had thought that we cannot use Gauss' Law to determine the flux through a SIDE of a cube since Gauss' Law only works for SURFACES. How can we determine how an electric field pierces a 2D-line?
Next, if I interpret the word "sides" as synonymous with "faces," I get answer choice E.
flux = charge / epsilon
flux = (5.0 * 10^-6) / (8.85 * 10^-12) = 5.6 * 10^5 (which is answer choice E)
Additionally, if the charge is located at a corner of the cube, wouldn't that mean that there would only be flux through 3 faces of the cube? I think this because wouldn't the electric field lines from the charge be parallel to the three faces that are adjacent to the corner where the charge is located? If I am correct in this interpretation, then the total flux through all sides of the cube would be calculated using
because we would divide total flux by 2 since only 3 / 6 faces are being "pierced" by the electric field. If I follow through with this calculation, I do not get answer choice B.
I have attached an image of the original problem as well as a solution that I found online that I am having trouble deciphering. I would be incredibly grateful for any help; I've been stuck on this problem for hours!
Gauss Law is applicable on surface which bound volume(This should be clear from derivation). First your solution is wrong since there is no symmetry argument that you can apply to lone cube. This is essential since you can't take out vector ##\vec E## from integration as it behaves differently at each surface. Coming to your doubt, note that you can imagine a big cube with centre as origin and section it in 8 equal pieces along all 3 axis from centre. Your cube is one of those 8 pieces. By placing charge at the centre of your big cube, you have made your system in which charge is placed at corner of all 8 small cubes. From here onward, symmetry arguments are valid and answer comes as you have shown in figure.
In the context of a solid body, side means face, not edge.
Thanks for your solution, I understand it now! I have one question regarding symmetry. I apologize as I'm still studying Gauss' Law so I hope to not come across as clueless. I thought the symmetry argument only applied to spherical, cylindrical, and planar surfaces. In the case of a large cube centered at the origin, wouldn't we still not be able to apply the symmetry argument as the surface is cubical?Additionally, why was my initial solution incorrect if I was not dealing with the integration of the electric field (which would require symmetry if we wanted to pull E out of the intergral)? I was merely calculating flux by dividing total charge by epsilon.
I understand the correct answer, but I was hoping you could clarify a little bit on the applications of the symmetry argument to this specific homework problem/question.
Gauss law is not a valid tool here simply because there is charge at the boundary (Introduction to Electrodynamics, Griffith). The field is not smooth on the surface. There is discontinuity! Hence, Gauss theorem is repealed and so does your method! By modifying the problem, Gauss law is made true as charge is enclosed within volume!
The flux through a cube of 8 times the size where the charge is at the center would be answer E. Your cube is 1/8 of that (with the other 7 identical). Hence answer B.
I don't think the exercise composer want you to worry like @Abhishek11235 in his/her last post: the faces with the charge in them simply have flux zero.
A common trick when using Gauss's law is to "force" a symmetrical interpretation when you're given a situation where the charge lies on what you would otherwise be a boundary of the Gaussian surface. As others have suggested, make it so that the charge lies at the center of a larger structure that would make the overall symmetry easy to analyze.
If the charge were to be surrounded by eight identical cubical spaces, then by symmetry the one cube that you're interested in would pass 1/8 the total flux produced by the charge:
  • · Replies 17 ·
9K
  • · Replies 22 ·
