Flux of electric field through the square
The problem involves calculating the electric flux through a square surface in the xy-plane due to a point charge located above it. The charge is specified, and the problem also considers a specific height relative to the size of the square.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the relevance of the equation for flux and the nature of the surface being open rather than closed. There is mention of integrating the electric field over the surface to find the total flux. One participant describes a conceptual approach involving solid angles and geometric reasoning related to a cube and a sphere.
The discussion includes various interpretations of the problem setup and the application of relevant equations. One participant claims to have arrived at a solution without integration, while others are still exploring the implications of the surface's geometry and the assumptions made about the flux calculation.
There is a noted confusion regarding the nature of the surface (open vs. closed) and the assumptions about the symmetry of the flux distribution. The specific height of the charge relative to the square surface is also a point of discussion.
leventa2
A small particle, with charge q = 8.85 μC, is located at (x,y,z) = (0,0,h). Calculate the flux of electric field through the square in the xy-plane, of size L × L, centered at the origin.
(B) What is the flux if h = 0.05 L?
Flux=Charge/permittivity (in a closed surface)
If h = 0.5 L, then I would just divide the flux by six. But I don't know where to go from here...
Contemplate the relevant equation you provided!
but how should I contemplate it? The surface is an open surface, and the flux is asymmetrical.
Ah, sorry. I jumped to the (incorrect) assumption that it was a square box, not just a square surface.
I suppose you'll have to integrate E.dS over the surface to determine the total flux.
Actually, I just solved it no integral necessary :D. Basically, I imagined the surface as part of a cube, and the cube surrounded by a sphere. Connecting the four corners of the surface to the electron in the center creates a square pyramid with base length L X L and height 0.05 L. I used the formula 4*arcsin((a^2)/(a^2+4*h^2)) to find the solid angle, and divided it by 4pi, the total solid angle. I multplied the resulting value by the total flux of the cube. It seems that solid angles play an important part in Gauss's law.
This was all tiring, but totally worth it when I got the correct answer.
Nicely done.
