Does Asymmetry in Spacecraft Flyby Trajectories Cause Unexpected Energy Gains?
Spacecraft on certain flyby trajectories around Earth experience unaccounted energy gains, particularly during asymmetric flybys, which produce the greatest increases in velocity. The asymmetry arises from the spacecraft approaching and departing at different latitudes, leading to questions about the average distance from Earth during these phases. It is posited that the spacecraft may be further from Earth when gravity is accelerating it before perigee and closer when decelerating after passing perigee. This phenomenon remains an open question, suggesting a need for further research into the underlying mechanics. The discussion references a paper proposing that special relativity might explain these anomalies.
Zman
It has been found that spacecraft on certain flyby trajectories around the Earth gain an amount of energy that is unaccounted for.
The asymmetric trajectories highlight this anomaly as described here http://en.wikipedia.org/wiki/Flyby_anomaly" .
I read that the most asymmetric flyby’s produce the greatest ‘unexpected increase’ in velocity.
The asymmetry refers to the fact that the spacecraft might approach at one latitude and leave by another. (I can't actually understand how this asymmetry occurs. Doesn't the Earth appear gravitationally as a point source?)
Anyway my main question is;
Does this asymmetry equate to the spacecraft ’s approach being on average further away from the Earth than its average distance from the Earth on the exit?
In other words: Is the spacecraft further from the Earth on average when the earth’s gravity is accelerating it positively just before it reaches the perigee?
And following on: Is the spacecraft closer to the Earth on average when the earth’s gravity is decelerating it after passing the perigee?
Astronomy news on Phys.org
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
