Force & Energy Homework: Calculate Weight
  • Thread starter Thread starter raman911
    Energy Force
The homework involves calculating the weight of a person with a mass of 120 lb (48 kg) using the formula w = mg, resulting in a weight of 470.4 N. The discussion confirms that this weight is correct. The next step is to determine the force required to push this weight up a 70-degree incline. Additionally, the problem includes calculating the magnitude and direction of the force needed for horizontal movement. The focus remains on applying physics principles to solve the incline and horizontal force components.
raman911
Assume that force the force required to walk from home to school is on a 70 degree angle to the horizontal surface. This force is equal to your weight.
mass is 120lb or 48 kg
a) calculate weight.
a)
w=mg
w=48kg*9.8N/kg
w=470.4N
IS THAT RIGHT?
470.4 N is the right weight. Now how much for does it take to push that weight up a 70 degree incline? I think that's the question.
b) calculate the mangitude and direction of the force that causes you to move in the horizontal direction.
