How Much Force Does It Take to Move a 300kg Cart with Small Wheels?
  • Thread starter Thread starter andryuxa1985
    Cart Force Wheel
To move a 300kg cart with small wheels, the required force depends on overcoming static friction at the wheel axles, which is proportional to the cart's mass. The wheel radius plays a crucial role in providing mechanical advantage, as it affects the torque needed to initiate rolling. A high center of gravity can make the cart unstable, especially if additional weight is placed on top. Small wheels may also struggle with uneven surfaces, impacting maneuverability. Hydraulic lift trolleys with similar weights can be moved by most people, indicating that with the right design, movement is feasible.
andryuxa1985
Hello Guys
i'm constructing some cart with conveyor on it
weight of cart with conveyor is 300kg
cart has 4 wheels
i need to know if one person could move it, or i need to make it lighter
how can i to calculate the force than person needs to move this cart?
does radius of the wheels influences on required force?
thank you
this is the conctruction
Yes, radius is the key to rolling. The force you have to overcome is the static friction at the axle of the wheels. This static friction is proportional to the mass of the cart. The radius is what gives you mechanical advantage. When you push, you are applying a latteral force to the center of mass of the cart. A reaction force is exerted by the floor at the perimeter of the wheel. As well as a reaction torque at the axle. Because the wheel is not completely constrained, it is able to roll. Rolling begins when the reaction force at the perimeter times the radius of the wheel exceeds the reaction torque at the axle.
A couple of observations on the design.
The centre of gravity is very high. That looks like a shelf or runner on top of it - any weight placed on that will make it even more unstable.
If it is a shelf or runner, any weight placed on the right hand side may move the CoG outside the right hand legs.
The wheels are small and may catch small objects or ridges in flooring.
To your original question - we use hydraulic lift trolleys at work with a safe working load of 300 kg. They weigh about that, so with a 200 kg load they come up about 500 kg. The wheels are about 200 mm in diameter. They are hard to steer and need a good push to get started but they can be moved by pretty much anyone.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
