- #1
EddieV
- 7
- 0
The pulley device is used to hurl projectiles from a ramp (Coefficient of Kinetic friction [mu] = 0.26) as illustrated in the diagram. The 5.0 kg mass is accelerated from rest at the bottom of the 4.0 m long ramp by a falling 20.0 kg mass suspended over a friction less pulley. Just as the 5.0 kg mass reaches the top of the ramp, it detaches from the rope (neglect the mass of the rope) and becomes projected from the ramp.
The ramp angle is 30 degrees
a) Determine the acceleration of the 5.0 kg mass along the ramp.
b) Determine the tension in the rope during acceleration of the 5.0 kg mass along the ramp.
c) Determine the speed of the projection of the 5.0 kg mass from the top of the ramp.
d) Determine the horizontal range of the 5.0 kg mass from the base of the ramp.
Let m1 = 5.0 kg
Let m2 = 20.0 kg
For a) I know how to solve the acceleration of the system with
(m2g - 0.26*m1g*cos30 - m1g*sin30)/(5+20)
So to find the acceleration of just the 5.0 kg block do I use this formula except only divide by 5 instead of 5 + 20. Or is the acceleration of the system also the acceleration of this block?
For b) I am pretty sure you do the acceleration of the system * m1 + Force of Kinetic friction which is 0.26*m1g*cos30
For c) I was thinking of using the big 5, knowing initial velocity is 0, displacement is 4.0 m, and either acceleration of the system or the accelerated I found in a) [unless they're the same acceleration]
For d) I would solve it as a projectile motion problem, I haven't really given it that much thought though
I feel most of my issues boil down to not knowing if the acceleration of the system is the same as the acceleration of the each block independently, and if they are separate values then how do you solve for them.
Thank you and have a nice day!
