What Is the Beat Frequency Between Two Close Tuning Fork Frequencies?
  • Thread starter Thread starter sonutulsiani
    Frequency Tuning
The discussion centers on calculating the beat frequency between two tuning forks with frequencies of 256 Hz and 258 Hz. The correct beat frequency is determined to be 2 Hz, which is the difference between the two frequencies. Participants note that while 2 Hz is the calculated beat frequency, it is not audible to the human ear. The consensus is that the only logical answer is 2 Hz, despite the fact that it falls below the audible range. The conversation highlights the nature of beat frequencies and their calculation.
sonutulsiani
Two tuning forks are struck and the sounds from each reach your ears at the same time. One sound has a frequency of 256 Hz, and the second sound has a frequency of 258 Hz. The underlying "hum" frequency that you hear is:
A. 2 Hz
B. 256 Hz
C. 258 Hz
D. 257 Hz
I got it as 2 HZ
Probably. Computer generated question?
The hesitation is because no one can hear 2 Hz.
Nah homework question!
Is it 2HZ?
yes, but I agree with Delphi--two hz is not audible. Beat frequencies are generated by sums and differences of the fundamentals. The only choice which makes sense is 2.
