Friction & Curves: Direction & Explanation
  • Thread starter Thread starter Supernejihh
    Curves Friction
When a car navigates a curve, the direction of friction is crucial for understanding its motion. Friction acts inward toward the center of the circle when the car is moving at maximum speed, providing the necessary centripetal force to maintain the turn. Conversely, at minimum speed, friction may point outward, as the car's inertia could cause it to slide outward. The relationship between speed and friction direction highlights the dynamics of circular motion. Understanding these concepts is essential for analyzing the forces at play in curved motion.
Supernejihh
If a car goes around a curve, which direction is its friction? Pointed towards the circle or outwards? Explain please. Thanks in advance.
That depends. Think about what happens when the friction is pointed inward in relation to the car's maximum and minimum velocities. Which way would the friction point if the car is moving at a maximum speed? At a minimum speed?
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
