Friction force in Newton's law
In summary: You are just comparing forces and determining the direction of friction. In summary, the block weighing 22 N is held at rest against a vertical wall by a horizontal force of magnitude 60 N. The coefficient of static friction is 0.55 and the coefficient of kinetic friction is 0.38. In six experiments, a second force is applied to the block and directed parallel to the wall with different magnitudes and directions. In each experiment, the frictional force is calculated using P - mg - fk = ma. The block will move when the applied force is greater than the maximum static friction force, and the direction of friction is determined by comparing P - mg with friction. The block will not move when the applied force is smaller than
theunloved
43
In Figure 6-63, a block weighing 22 N is held at rest against a vertical wall by a horizontal force of magnitude 60 N. The coefficient of static friction between the wall and the block is 0.55, and the coefficient of kinetic friction between them is 0.38. In six experiments, a second force is applied to the block and directed parallel to the wall with these magnitudes and directions: (a) 34 N, up, (b) 12 N, up, (c) 48 N, up, (d) 62 N, up, (e) 10 N, down, and (f) 18 N, down. In each experiment, what is the frictional force on the block, including sign? In which does the block move (g) up the wall and (h) down the wall ? (i) In which is the frictional force directed down the wall ?
How I attempted to solve:
Taking upwards as positive, x+ from left to right
If the block is at rest, then:
fs <= us N = 0.55 * 60 = 33N
fk = uk N = 0.55 * 60 = 22.8N
Part a.
P = 34 N, up.
P is greater than fs at max, so the block must move, and friction is going down.
P - mg - fk = ma
Ok, from here, I really kinda confused. If you don't know the sign of frictional force, how are you going to write down Newton's second law ? and also, we don't know acceleration too, how are we going to calculate fk ?
Part b, e, f, the block can't move, because P is smaller than fs at max...
Where is the figure?
theunloved said:
Part a.
P = 34 N, up.
Don't forget about gravity when deciding if the block must move and determining the direction of friction. You need to compare P - mg with friction, not just P.
P - mg - fk = ma
The proper reasoning as above will tell you the direction and thus the sign of the friction force.
Why would you need the acceleration?
1. What is friction force in Newton's law?
Friction force is the force that opposes the motion of an object when it comes into contact with another object or surface. It is a fundamental concept in Newton's laws of motion and is responsible for many everyday phenomena, such as walking, driving, and writing.
2. How is friction force related to Newton's laws of motion?
Friction force is directly related to Newton's first law of motion, also known as the law of inertia. This law states that an object at rest will remain at rest and an object in motion will continue to move in a straight line at a constant speed unless acted upon by an external force. In the case of friction, this external force is the opposing force that slows down or stops the motion of an object.
3. What factors affect the amount of friction force?
The amount of friction force depends on several factors, including the type of surfaces in contact, the force pressing the surfaces together, and the roughness of the surfaces. For example, rougher surfaces will have a greater friction force compared to smoother surfaces.
4. How is friction force calculated?
The magnitude of friction force can be calculated using the formula F = μN, where F is the friction force, μ is the coefficient of friction, and N is the normal force (force perpendicular to the surfaces in contact). The value of μ depends on the two surfaces in contact and can be determined experimentally.
5. What are the different types of friction force?
There are three main types of friction force: static friction, kinetic friction, and rolling friction. Static friction occurs when an object is at rest and is about to be moved, while kinetic friction occurs when an object is already in motion. Rolling friction is the force that opposes the rolling motion of an object, such as a ball rolling on a surface.
