Friction Loss in Y-type Pipe Calculation
Calculating friction losses in a suction inlet pipe for a fire pump involves considering the configuration of the pipes, specifically the transition from two 5" pipes to a 6" diameter at the pump inlet. While straight pipe and bend calculations are straightforward, interconnecting pipes require a different approach. It's suggested to average the friction loss of a straight pipe and a 45-degree bend due to inherent inaccuracies in friction loss calculations, influenced by variables like temperature and velocity. Contacting the manufacturer for a K value may provide more precise data. Utilizing the equivalent length for a miter bend, as referenced in Crane 410, is also recommended for better accuracy.
simelliott
Hi all,
I am trying to calculate the friction losses found in a suction inlet pipe for a fire pump. I have attached an image which shows the pipe we are intending to use, but have no idea how to calculate the expected friction losses we would find when using it.
I know how to calculate for straight pipe and for bends, but no idea about interconnecting pipes such as this?
The section consists of 2 x 5" pipes joining into a 6" diameter at the pump inlet. The angle of the 5" pipes is 90 degrees if that helps?
Does anyone have any suggestions on where to start?
Thanks in advance.
How accurate does your estimate need to be? You could just take the average of a straight pipe and a 45 deg bend. Friction loss calculations are a good deal of inherent error to begin with, as there are many variables such as temperature, Re number, velocity, actual wall roughness, etc that can make the typical models highly inaccurate. Your best bet may be to contact the manufacturer of the fitting to see if they have a K value.
Assuming one of the branches has no flow in it, I would use the equivalent length for a miter bend of the same angle as indicated in Crane 410 (attached).
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
