Frictional force between two rotating cylinders
The discussion centers on the frictional force between two rotating cylinders, specifically cylinder P, which rotates at a constant angular velocity ωP, and cylinder Q, which is free to rotate and makes contact with P at an angle θ. In steady state, cylinder Q achieves a constant angular velocity, and the frictional force acts parallel to the axis of Q, ensuring no slipping occurs. The participants clarify that while there is no relative motion in steady state, friction is necessary to maintain the angular velocity of cylinder Q, which is influenced by the motor-driven rotation of cylinder P.
  • Understanding of angular velocity and its implications in rotational dynamics
  • Knowledge of frictional forces and their role in motion
  • Familiarity with the concept of steady state in mechanical systems
  • Basic geometry related to angles and motion in rotating systems
  • Study the principles of rotational dynamics and angular momentum conservation
  • Learn about the effects of friction in mechanical systems, particularly in rotating bodies
  • Explore the concept of steady state in various physical systems and its implications
  • Investigate the geometric relationships in rotating systems, including contact points and angles
Mechanical engineers, physics students, and anyone interested in the dynamics of rotating systems and the role of friction in maintaining motion.
Dayal Kumar
.A cylinder P of radius rP is being rotated at a constant angular velocity ωP along positive y-axis with the help of a motor about its axis that is fixed. Another cylinder Q of radius rQ free to rotate about its axis that is also fixed is touched with and pressed on P making an angle θ between their axes. Soon after the cylinders are pressed against each other, a steady state ls reached and the cylinder Q acquires a constant angular velocity. What can you conclude about the direction of frictional force when the steady state is reached?
I am getting that cylinder q will be rotating with a fixed angular velocity in the steady state and also it's centre of mass will be translating with ωQrQtanθ along the fixed axis of rotation. I am unable to understand why there will be frictional force if there is no acceleration or relative motion.
Have you provided the exact wording of the problem?
Hello Dayal, :welcome:
Would that be consistent with 'steady state' ?
And: would it be consistent with 'no frictional force in action' ?
The wording of the question is correct.
I think I am not getting what exactly is happening at the contact point. In steady state there should not be any slipping between the surfaces, what will happen to the angular velocities of the cylinders in such a case, please explain??
I am not able to picture the geometry. Can you provide a diagram please.
I believe it looks like crossed fingers.
I think there is relative motion between the two because of the angle.
Try drawing rings around both rollers representing the motion of the point of contact. Two points on these rings converge on the contact point at different angles.
It says it is free to rotate about its axis. There is nothing about whether it is free to slide along its axis. I would assume not.
I have now understood that there must be relative motion between the two and the steady state is reached when the direction of frictional force becomes parallel to the axis of Q such that it's angular velocity remains constant. Thank you for your instructive replies.
It is not very intuitive, but I agree with your answer. Thank you for posting such an interesting question.
I'll have to think about it some more. I thought from symmetry the angle of the frictional force would be theta/2.
There does not actually exist any symmetry because the motor attached to cylinder P makes it rotate at a specified constant velocity whereas the friction is responsible for making the cylinder Q reach to the constant angular velocity as required in the steady state.
Ok that didn't take long. I agree with you. The frictional angle will change as Q accelerates but once the angular velocity becomes constant it stops parallel with the axis of Q so the isn't a tangential component.
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 60 ·
