From the balanced equation
In summary, a balanced equation is a chemical equation that shows an equal number of atoms for each element on both sides. It is important because it accurately represents a chemical reaction and follows the law of conservation of mass. To balance an equation, coefficients must be adjusted. If an equation is not balanced, it means the number of atoms of each element is not equal, resulting in an inaccurate representation. Subscripts cannot be changed to balance an equation as they represent the number of atoms in a molecule.
Dan350
44
From the balanced equation:
C3H4O2 (liquid) + NaOH → C3H3NaO2 + H2O
Calculate how much Acrylic Acid and Sodium Hydroxide would be needed to have a 5 M concentration in the monomer C3H3NaO2. Use as little Acrylic Acid and Sodium Hydroxide as possible. (Hint: use mL)[/B]
I used a solver, but I got it incorrect on the assignment
And what is your question?
What is a balanced equation?
A balanced equation is a chemical equation that shows the same number of atoms of each element on both sides of the equation.
Why is it important to have a balanced equation?
A balanced equation is important because it accurately represents the reactants and products involved in a chemical reaction and follows the law of conservation of mass.
How do you balance an equation?
To balance an equation, you must adjust the coefficients (numbers in front of the chemical formulas) to make sure that the number of atoms of each element is the same on both sides of the equation.
What does it mean if an equation is not balanced?
If an equation is not balanced, it means that the number of atoms of each element is not equal on both sides of the equation. This can result in an inaccurate representation of the chemical reaction.
Can you change the subscripts in a chemical equation to balance it?
No, you cannot change subscripts in a chemical equation to balance it. Subscripts represent the number of atoms of an element in a molecule and changing them would change the identity of the compound.
