Understanding the Transition to Turbulent Flow in Pipe Systems
As fluid flows through a pipe, the shear stress at the wall initially decreases as the boundary layer develops. However, as the flow transitions to turbulent conditions, the shear stress increases significantly, often exceeding the levels observed during laminar flow. This transition creates a discontinuity in the shear stress profile along the pipe's length. The phenomenon is contingent upon achieving a sufficiently high Reynolds number for turbulence to occur. Understanding this transition is crucial for predicting flow behavior in pipe systems.
bortonj88
Hi
As fluid enters a pipe and progresses further down, does the shear stress at the wall reduce whilst the boundary layer increases and viscous forces take over?
Thanks
It is a little more complicated. As the boundary layer develops, the shear stress goes down, however, as you get farther down the pipe, the flow will transition to turbulence, at which point the shear stress jumps through the roof again and, while it does decrease somewhat after that, it is typically higher than at any point while the flow was still laminar. In other words, if you plotted \tau_w vs. x, there would be a discontinuity at the point where the flow transitions. This assumes you have a high enough Reynolds number to go turbulent of course.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
