Function Counter: Counting # of Functions in a File - Tips & Ideas
The discussion focuses on creating a C program to count the number of functions in a file by tracking the opening and closing braces. Warren suggests reading the file one token at a time, using a counter that increments for each '{' and decrements for each '}'. He also mentions that using regular expressions could be a more advanced approach for parsing .cpp files. The conversation highlights the importance of understanding file reading techniques in C, particularly the use of the istream class and character processing.
  • Understanding of C programming language
  • Familiarity with file I/O operations in C
  • Knowledge of tokenization and parsing techniques
  • Basic understanding of regular expressions
  • Implement a function to read a file character by character in C
  • Explore regular expressions in C++ for advanced parsing
  • Learn about the C++ string class for dynamic string handling
  • Study the differences between token-based and character-based file processing
C developers, software engineers working with C/C++ file processing, and anyone interested in function counting and parsing techniques in programming.
Stanley_Smith
Hi everyone,
I need to write a C code program to count the # of fuctions used in a certain file (function counter)
Can you guys give me some hints/suggestions/ideas ?
Thanks,
Stan
Do you know how to read in a file one token at a time? You should be able to read each { and } symbol as an independent token. If you keep a running count of the braces, adding one for each { and subtracting one for each }, the number of functions in the file is the number of times the counter goes from zero to one.
Of course, this is primitive -- in the real world, I would probably use regular expressions to match each line of the .cpp file.
- Warren
Thanks, Warren for the response.
Can you please show me how to read in a file one token at a time...
Stanley,
Something like this:
PHP:
#include <iostream>
int main( int argc, char** argv )
    char str[100];
    // don't read more than 100 characters
    // and overflow the buffer
    cin.width(100);
    while( !cin.eof() )
        cin >> str;
    return 0;
You could use the string class, instead of a char*, so you don't have to have an upper bound on the size of a read.
But that doesn't read it in one token at a time, does it? Isn't, for example wouldn't,
{return(0);}
be something like 7 tokens? But they'd all be read in at once.
Wouldn't it be conceptually easier to process the file one character at a time?
Yeah, true, Hurkyl, I don't know how the istream class treats punctuation. You're probably right, it doesn't treat (){}* etc. as delimiters.
You're right, reading one character at a time might be easier.
- Warren
12K
  • · Replies 33 ·
