FYP inquiries - Vertical-axis Wind Turbine
The discussion centers on a Mechanical student's Final Year Project focused on designing a vertical-axis wind turbine as part of a hybrid power generator with solar energy. The student seeks guidance on where to start, expressing a lack of experience in building such projects. Suggested resources include websites with extensive information on wind power and historical books that provide foundational knowledge. Participants recommend beginning with calculations, selecting a suitable generator, and exploring blade design. The conversation emphasizes the importance of thorough research and understanding basic concepts in wind energy.
jacksonywl
Hi, I am a Mechanical student, currently at my final year so I am to do my FYP aka Final Year Project with the title of hybrid power generator (solar + wind). My friend is in charge of the solar part while I am to design a vertical-axis wind turbine.
I am clueless about from where should I start. Can anyone please guide me?
Thank you so much in advance.
This website seems to have extensive information on wind power.
http://www.otherpower.com/otherpower_wind.shtml
In particular, these plans.
http://www.otherpower.com/turbineplans.shtml
I plan to build this myself when more resources are available.
*EDIT* At the time of writing, I had no idea what a "Vertical Axis Wind Turbine" was. With some googling, I see that my links are probably not much help, although the design for the alternator may be useful.
Hi there. I will be sure to go through the sites you gave.
Meanwhile, I am just wondering, since I have not much experienced in building real thing, so, I want to know what are the steps I should start with. For eg, calculation? find a suitable generator 1st? find out suitable blade design? Stuff like these..
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
