General electric field question
To determine the electric field at a point with a positive test charge, one must consider the contributions from surrounding charges. When two positive charges are present, the electric field strengths are calculated and the larger value is subtracted from the smaller. In the case of a positive and a negative charge, the electric fields are added together due to opposing forces. For multiple charges at varying distances, the electric fields are summed to find the total. It is essential to include the direction of the electric fields, as they are vector quantities.
Jabababa
So let's say i have a positive test charge of P, and all the problems are to find electric field.
ex 1: If test charge P is in the middle of 2 positive charge, I find both Electric field strength and use the bigger number minus the smaller number.
ex 2: If test charge P is in the middle of a positive and negative charge, i find both Electric field strengths and add them together because the positive will repel and the negative will attract.
ex 3: if test charge P is at the very right side with 2 positive charges on the left both at different distance from the test charge. I add both Electric field together.
Did i nail the concept of this? And do i need to give a direction for electric field?
I would suggest that you draw a diagram for each of the situations and show the directions of the electric fields at the points you are interested in.
Then the total electric fields will be clearer.
You need to give directions for the electric fields since they are vector quantities.
