How Do You Rotate a Complex Number by 270 Degrees?
Rade
Question, in order to produce a 270 degree geometric rotation of the complex number (a + bi), would this be correct:
(a + bi) * (-i)
It seems logical since a 90 degree rotation results from (a + bi) * (i)
Next question. What would be the equations for rotation of (a + bi) by 45 degrees, 135 degrees, 225 degrees ?
Thanks for help.
hypermorphism said:
Do you know the Euler formula ?
Is it standard here in the math section of the forum to answer a question with a question ?
You can either think of complex numbers as vectors and hence use a suitable transformation matrix, or you can think about their arguments (i.e. the angles they make with the +ve real line).
So, yes, multiplication by -i will rotate a complex number by 270 deg (in the anticlockwise direction), since the argument of -i is 270, and when you multiply complex numbers you add their arguments. This is what hypermorphism was hinting at: Euler's formula can prove this. Since if z=a+ib and w=c+id are two complex numbers with arguments p and q, then z=|z|e^(ip) and w=|w|e^(iq), and hence zw=|wz|e^(i(p+q)).
So in the spirit of the standard of answering a question with a question:
Can you see how to apply this to rotations of any degree? :smile:
Thanks for your help. I am not a mathematician--obvious from the question--since the answer ends up being basic. I see the degree rotations (0 to 360) of a complex number (a + bi) when operated on by i being related to raising (i) to various powers, thus (a + bi) * i ^ 1 = 90 degree rotation, * i ^ 2 180 degrees, * i ^ 3 270 degrees, * i ^ 4 360 (or 0 degrees). To find any single degree rotation one must find the correct power of i by which (a + bi) is multiplied,--so, is there a Table of Powers of i that give all 360 degrees--perhaps an internet link ?
As devious_ mentioned (and what follows from Euler), the argument of the product of two complex numbers is the sum of their arguments*. So if you want to rotate by x degrees, you'd want to multiply by a number whose argument is x degrees. The argument of e^{ix} is x radians*, and it's absolute value is 1 (the absolute value needs to be 1 if you just want a rotation). Convert degrees to radians, and use Euler's if you want to get in a+bi form.*modulo the multivalued nature of the argument, i.e. up to multiples of 2*pi
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
