Gravitational field of a hollow sphere
The discussion focuses on the calculation of the area of a thin ring on a hollow sphere, specifically addressing the formula 2πasinθ ds. Participants clarify that the ring can be viewed as a trapezoid, but emphasize that the height used in the area calculation should be ds sinθ, not ds. The conversation highlights the importance of visualizing the infinitesimal strip correctly, noting that ds is perpendicular to the edges of the strip, allowing for a straightforward area calculation as a rectangle. The integration of the area element over θ from 0 to π is suggested to confirm the total surface area of the sphere. The key takeaway is the correct interpretation of geometric relationships in the context of the hollow sphere's gravitational field.
Rikudo
Why the area of the thin rings are ##2πasin\theta \, ds##? (a is the radius of the hollow sphere)
If we look from a little bit different way, the ring can be viewed as a thin trapezoid that has the same base length ( ##2πa sin\theta##), and the legs are ## ds##.
The angle between the leg and the lower base is ##90-\theta##. Hence,we can conclude that the height of the trapezoid is ##ds \, sin\theta##.
Since the base length is more or less the same, the area is just base x height.
This means, the area is :##2πa sin\theta \, ds \, sin \theta##.
Why don't you substitute ##ds=a~d\theta##, then integrate your area element over ##\theta## from ##0## to ##\pi##. Do you get ##4\pi a^2## for the area of the shell?
Yes.
But, ##ds## is not the height of the trapezoid. So, in my opinion, we are not supposed to multiply this with the ##2πa sin\theta## to get the area.
Rikudo said:
the height of the trapezoid is dssinθ.
Sure, but the height of the trapezoid is not what you need. A wall length L and height H has area LH. If it then leans over at angle θ it still has area HL, not HL cos(θ).
Likes Rikudo, kuruman, Orodruin and 1 other person
Umm... well, it is is true, but what is the relation of it with the area of ring?
Why, though? We can't use ##ds## as its height since it is not perpendicular to the bases.
@Rikudo, I suspect your difficulty arises because you are not 'visualising' the infinitessimal 3D strip correctly.
The line element ##ds## is perpendicular to both the inner and outer edges of the strip. That means the (infinitessimal) strip has the same area as a rectangle measuring ##2\pi a \sin \theta## by ##ds##.
Likes Rikudo and erobz
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
