Are Equipotential Surfaces Around Parallel Wires Really Circular Cylinders?
The discussion centers on the nature of equipotential surfaces around two parallel wires with opposite linear charge densities. Initially, there is confusion about whether these surfaces can be described as circular cylinders, with some participants arguing that the resulting shapes appear more like hyperbolas. However, through algebraic manipulation, it is shown that the equations derived do indeed represent cylindrical surfaces, albeit offset from the wires. The conversation emphasizes the importance of correctly interpreting the mathematical results to align with established electrostatic principles. Ultimately, the conclusion is reached that the equipotential surfaces are indeed cylindrical, confirming the book's assertion.
rachmaninoff
I've been going back over Griffiths' E&M this summer, and this question (2.47, electrostatics) is making me stupid:
There are two 'infinite' wires, parallel to each other, with linear charge densities + \lambda and - \lambda;
and the question asks to show that the equipotential surfaces are "circular cylinders".
I don't see how any cylinders could be equipotentials, and in doing the algebra,
(lines parallel to the x axis, + charged one going through (0,d,0), - charged one going through (0,-d,0)
V(x,y,z)= -\frac{\lambda}{2 \pi \epsilon _0} \left[ \log \sqrt{ (y-d)^2 + z^2 } - \log \sqrt{ (y+d)^2 + z^2 } \right]
\begin{align*}V(r)=V_0 &amp;\Longrightarrow \frac{(y-d)^2+z^2}{(y+d)^2+z^2}=e^{-\frac{4 \pi \epsilon_0}{\lambda} V_0}=C&gt;0 \mbox{ (absolute value signs go away, both the top and bottom are everywhere &gt; 0) } \\<br /> &amp;\Longrightarrow (y-d)^2+z^2 = C\left( (y+d)^2+z^2 \right) \\ &amp;\Longrightarrow y^2+z^2+d^2-2yd=C\left(y^2+z^2+d^2+2yd \right) \\<br /> &amp;\Longrightarrow (1-C)y^2+(1-C)z^2=-(1-C)d^2+4Cyd \end{align}
or,
\begin{align*}r^2&amp;=-d^2+\left( \frac{4C}{1-C}\right) yd, (C &gt; 0) \\<br /> &amp;= d(ky-d), k \in (-\infty,4) \cup (0, + \infty) \end{align}
Which seems to make physical sense - the equipotentials are a family of curves which include y=0 (where V=0!) and curves that look sort of like hyperbolas (all extending to infinity). There are no 'cylindrical' solutions.
Where am I going wrong?
Edit: my last simplification left out the important C = 1 case, the more general equation was (for the equipotentials):
(1-C)y^2+(1-C)z^2=-(1-C)d^2+4Cyd, (C &gt; 0)
(from my above post).
That's where you get the equipotential plane y=0: set C=1.
Dear rachmaninoff,
The formula for a cylinder centered on the x-axis is:
\kappa y^2 + z^2 = \lambda
where \kappa, \lambda are constants. When you offset such an equation by arranging for the cylinder to be centered on a line going through (0,\alpha,0), that is, a line parallel to the x-axis but offset by some amount in the y-axis, the formula becomes:
\kappa (y-\alpha)^2 + z^2 = \lambda
I think that when you compare this with your formula:
you will see that the book is right about it being the equation for a cylinder.
Carl
I'm not sure what you mean, there are two charged wires involved (not one), with opposite charges, parallel and with distance 2d between them, and the potential due to each one is
V(y,z)=-\int_{O}^{(x,y)} \frac{1}{2 \pi \epsilon_0} \frac{\pm \lambda}{\sqrt{(y\pm d)^2+z^2}}dl
=\mp\frac{ \lambda}{2 \pi \epsilon} \log | \sqrt{(y\pm d)^2+z^2} | +V_0
My point is that when you superimpose the two potentials, you don't get any equipotential cylinders, which is why my 'formula' is different from the book formula for a cylinder. That's my problem.
rachmaninoff said:
... curves that look sort of like hyperbolas (all extending to infinity).
Your problem is that you were just wrong in this statement. The curves don't look at all like hyperbolas. They're cylinders. The book is right, you're wrong. This is the normal order of the universe. Don't feel bad, it's not all that obvious.
The equation defining the surface that you gave was correct:
y^2 + z^2 =-d^2+\left( \frac{4C}{1-C}\right) yd, (C &gt; 0)
Let me rewrite it for you so that it becomes more obvious that this is a cylinder. Complete the square for y:
\left(y-\frac{2dC}{1-C}\right)^2 + z^2 =<br /> d^2\left(\frac{4C^2}{(1-C)^2}-1\right) = \Delta^2
This is the equation for a cylinder with center (0,2dC/(1-C),0) extending in the x direction, and with a diameter of \Delta . Note that the cylinder is not centered on either of the two wires (as were those wires' equipotential surfaces in the absence of the other wire). Instead, the cylinders get pushed away from the other wire.
If you still have doubts about this, you need to fix it because this is really very basic electrostatics. Here's an applet that will help you visualize the situation:
http://www.falstad.com/emstatic/index.html
In the above, click on "dipole charge" to see the way the cylinders look.
Now think carefully about what you are saying, that is, that the equipotential surfaces extend to infinity. Do you really think that it is physically realistic for a pair of wires (whose charge adds to zero) to have a field that extends to infinity with an undiminished intensity?
Carl
Thanks, I got it!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
