Griffiths' QM book: series solution to harmonic oscillator
tjkubo
I'm trying to read through Griffiths' QM book, and right now I'm on the series solution to the harmonic oscillator (ch 2). I'm having a hard time following the math (especially after equation 2.81) in this section, so if anyone has read this book, please help.
My first question is about the recursive formula
a_{j+2}=\frac{2}{j}a_{j}
The text says the approximate solution is
a_{j}=\frac{C}{(j/2)!}
How was this derived?
Second, how was the following derived?
\displaystyle\sum \frac{C}{(j/2)!} \xi^j \approx \displaystyle\sum \frac{1}{j!} \xi^{2j}
Third, the first paragraph on page 54 is totally baffling to me. Why must the power series terminate? Why must an+2 = 0? How does this truncate either heven or hodd? I think if I can get through this paragraph the rest will come naturally.
First question
If
a_{j+2}=\frac{a_{j}}{j/2}
Then
a_{j}=\frac{a_{j-2}}{(j-2)/2}= \frac{a_{j-2}}{(j/2)-1}
so that when I replace this in the first equation, I get
a_{j+2}=\frac{a_{j-2}}{(j/2)(j/2-1)}
Now write aj-2 in terms of aj-4, replace and keep on going down in indices until you reach a0 which is a constant, call it C.
Second question
Let k = j/2. Then j = 2k so that
<br /> \displaystyle\sum \frac{C}{(j/2)!} \xi^j \approx \displaystyle\sum \frac{1}{k!} \xi^{2k}<br />
But k is a dummy index and can be replaced by j.
Third question
The recursion relation 2.81 is good for either even or odd j. That is how it truncates either heven or hodd. Think what would happen if the series did not terminate and ran all the way out to infinity. You would not be able to match the asymptotic behavior for large ξ (Equation 2.76).
Good luck getting through the rest of the section.
Thank you, kuruman. That was very helpful!
However, I'm still having trouble understanding the paragraph on page 54. I think I now understand why the series must terminate, but I still don't see why if n is for example even, the odd powers must disappear. Why can't h(ξ) = a0 + a1ξ + a2ξ2 for example? Why does h(ξ) have to include only even powers or only odd powers? I hope this makes sense.
The discussion on page 54 shows you how to calculate the coefficients aj once you have chosen a value of n, i.e. for given energy eigenstate. Note that the maximum value that j can have before the series terminate is n. So if n is even, only the even powers in h(ξ) can and will be terminated while the odd powers will all be present. This means that the wavefunction will blow up for large ξ unless none of the odd powers are present to begin with, i.e. a1=0. Naturally, if n is odd, then you must set a0=0 for similar reasons.
Also, when you have a symmetric potential, i.e. V(-x) = V(x), as in this case, the energy eigenstates are either even or odd functions. This is because the Hamiltonian operator commutes with the parity operator. If you don't know what I am talking about (this stuff is in the next chapter of Griffiths), accept the previous explanation and move on. What I just said will be clearer later.
i want the sclution for ( 1-d) harmoio oscillator by serise
Iwant the sclution for ( 1-d) harmonic osillator by bra and ket
Thread 'Need help understanding this figure on energy levels'
This figure is from "Introduction to Quantum Mechanics" by Griffiths (3rd edition). It is available to download. It is from page 142. I am hoping the usual people on this site will give me a hand understanding what is going on in the figure. After the equation (4.50) it says "It is customary to introduce the principal quantum number, ##n##, which simply orders the allowed energies, starting with 1 for the ground state. (see the figure)" I still don't understand the figure :( Here is...
Thread 'Understanding how to "tack on" the time wiggle factor'
The last problem I posted on QM made it into advanced homework help, that is why I am putting it here. I am sorry for any hassle imposed on the moderators by myself. Part (a) is quite easy. We get $$\sigma_1 = 2\lambda, \mathbf{v}_1 = \begin{pmatrix} 0 \\ 0 \\ 1 \end{pmatrix} \sigma_2 = \lambda, \mathbf{v}_2 = \begin{pmatrix} 1/\sqrt{2} \\ 1/\sqrt{2} \\ 0 \end{pmatrix} \sigma_3 = -\lambda, \mathbf{v}_3 = \begin{pmatrix} 1/\sqrt{2} \\ -1/\sqrt{2} \\ 0 \end{pmatrix} $$ There are two ways...
