Do I Need Freewheel Diodes for My H Bridge Mosfet Inverter Circuit?
In summary: Adding freewheel diodes is only something you need to do with certain devices, BJT for sure, IGBT also natively needs it, although some are co packaged with diodes, if using bare die then IGBT needs a diode.
khalil977
TL;DR Summary
hello i am designing H bridbe mosfet inverter with gate driver HCPL3120 i need help in circuit please help circuit diagram with all four drivers connected i am very confused about that please help me
Thanks
Post a diagram of what you’ve got so far.
Plz correct my circuit diagram thanks
What is wrong with the way the circuit works? Have you scoped it?
Welcome to PF.
The driver is capable of 2 amps, but you show 10k gate resistors.
I would expect 10 ohms.
You may need to connect the source of each mosfet to the pin 5 common output of the floating driver chip.
You must provide a boosted supply voltage for each high-side driver. That will require a capacitor and diode on each high-side driver.
Additional information required before revision of circuit diagram.
1. Is pin 3 common ground on the J2, J3, J4 & J5 ?
2. What is the J7 positive voltage?
3. What is the J8 negative voltage?
The IRF740 suggests you will be using high voltages, greater than the opto-isolator can handle, so you will need a floating supply for the low side switch, with a diode and capacitor for the high-side switch. That is necessary to turn on, and hold the hi-side switch on because the gate voltage must be higher than the positive supply rail.
You must find some way of preventing both Hi and Lo sides being turned on at the same time. I think there are better half-bridge drivers available that will prevent both switches conducting at the same time.
If you are driving an inductive or motor load you will need flyback or freewheel diodes across all mosfets.
Here is an improved half-bridge circuit using the HCLP-3020 and IRF740.
Use two half-bridge circuits to make a full H-bridge.
243950
Definitely. Belt and Suspenders definitely. GPS IIA drove their solar arrays with an H-bridge. The 'legs' were controlled by a pair of light-sensing diodes arranged with a 'null' when aimed at the sun. Reactive components were added to the GPS II design as part of a hardening exercise. Reactive components + slip-ring (intermittent) connections = high-rate spikes. There are no service calls to 12,500 miles.
Mosfets have the intrinsic body diode that serves the purpose of freewheeling for all but the most demanding situations, where some people will put a schottky in parrallel to reduce conducted losses and reduce reverse recovery, although most of the gains can be had by active rectification, ie turning the FET on if its conducting regardless of the direction of current flow.
1. Do I really need freewheel diodes for my H bridge MOSFET inverter circuit?
Yes, freewheel diodes are essential for proper functioning of an H bridge MOSFET inverter circuit. Without them, the circuit can experience voltage spikes and other issues that can damage the components and reduce overall efficiency.
2. What do freewheel diodes do in an H bridge MOSFET inverter circuit?
Freewheel diodes, also known as flyback diodes, provide a path for the current to flow when the MOSFET switches are turned off. This prevents voltage spikes and protects the MOSFETs from damage.
3. Can I use any type of diode as a freewheel diode in my H bridge MOSFET inverter circuit?
No, it is important to use fast recovery diodes or Schottky diodes as freewheel diodes in an H bridge MOSFET inverter circuit. These types of diodes have a fast switching speed, which is necessary for the high frequency switching in the circuit.
4. How do I determine the appropriate freewheel diode for my H bridge MOSFET inverter circuit?
The freewheel diode should have a voltage rating at least equal to the supply voltage of your circuit. It should also have a current rating that is higher than the maximum current that will flow through it.
5. Can I use only one freewheel diode for the entire H bridge MOSFET inverter circuit?
No, each MOSFET in the H bridge requires its own freewheel diode. This ensures that the current is properly diverted and prevents any potential damage to the circuit.
  • Electrical Engineering
