H2O2 Stability in Water at 5-10 Degrees
  • Thread starter Thread starter endlez wonder
    Stability
Diluted hydrogen peroxide (H2O2) does not remain stable for long periods, even when stored at low temperatures (5-10 degrees Celsius). Users mixing a 6% solution from a 50% concentration can expect the solution to maintain its effectiveness for only a few hours. It is important not to seal the container tightly, as the concentration will decrease as the peroxide reacts with contaminants on surfaces, evidenced by bubbling during application. Historical data indicates that diluted H2O2 can be stored for a maximum of four days at room temperature, with lower concentrations being less effective. Caution is advised when handling high concentrations, as they can pose fire hazards if they come into contact with flammable materials.
endlez wonder
Does H2O2 stay stable once diluted in Water kept at 5-10 degrees. If so for how long?
Chemistry news on Phys.org
It doesn't.
I am attempting to clean a screen with H2O2 based on the manufacturers recomendations. I am mixing a 6% solution of H2O2 (50% conc) and water. I trust I should be able to count on 6% for a few hours! Am I wrong:(
It'll last that long. Don't cap it tightly. As the peroxide works on the stuff on the screen and the screen itself, the concentration will go down. You should see bubbles on the screen throughout the process.
http://www.bold-tech.com/technical/piranha_etch.html" It works!
My previous company produced it in batch quantities at 1% and stored it for a 4 days at the most at room temperature. It isn't that interesting at low concentrations however there are all sorts of problems with it at high concentrations - be certain to not get it on flammable surfaces e.g. wood and even leather shoes if you are wearing one even a few drips may cause it to catch fire.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
