Half life and the age of a planet
In summary, a newly discovered exoplanet that is 500 light-years away has an abundance of potassium-40 to potassium-39 at 99.9%, indicating that there are 999 potassium-40 atoms for every 1000 potassium-39 atoms. Using the half-life equation, the age of the planet is calculated to be 8.48 x 10^7 years or 6.6 half-lives. There was some confusion regarding the percentage and ratio, but it was determined that the ratio is correct and the age calculation was solved.
stunner5000pt
1,461
An extra solar planet is discovered that is 500 light-years away. It is found through spectroscopic analysis that the abundance of potassium - 40 to potassium - 39 on the planet is 99.9%. Assuming that the planet was created with equal amounts of the two potassium isotopes, how old is the planet?
2. The attempt at a solution
K-39 is stable with 20 neutrons
K-40 half life is 1.277 x 10^7 years
K-40 decays to Ar-40 but that is stable.
Since K-39 and K-40 were in equal proportion to begin with
[itex]A_{0} = 0.5[/itex]
[itex]A(t) = 0.01[/itex]
we can use the half life equation
[tex] A(t) = A_{0} \left(\frac{1}{2}\right)^{t/h}[/tex]
And solving for t=8.48 x 10^7 s [/tex]
But the light from this planet took some time to reach us - 500 light years. But that doesn't make much of a difference
So the answer is 8.48 x 10^7 years or 6.6 half lives.
Am i right? Please advise
What does the ratio mean in terms of percentage? Please check your data. Do you mean that K40 is 99.9% of the total K?
A(t) = .999 not 0.001
because the ratio is K-40/K-39 so there is 999 K-40 for every 1000 K-39
is that correct??
is that correct??
That sounds a bit reasonable. Then you have to find t from:
0.999 = 1*(1/2)^(t/h).
Thanks for the help
This question is solved :)
Related to Half life and the age of a planet
1. What is half life?
Half life is the amount of time it takes for half of the radioactive material in a substance to decay into a stable form. It is a constant rate of decay that is unique to each radioactive element.
2. How does half life help determine the age of a planet?
By measuring the amount of radioactive material and its decay rate in a rock sample from a planet, scientists can use the half life formula to calculate how long it has been since the rock formed. This gives an estimated age for the planet.
3. What is radiometric dating?
Radiometric dating is a method used by scientists to determine the age of a substance by measuring the amount of radioactive material present and its decay rate. This can be used to estimate the age of a planet or other objects in the universe.
4. Can half life be used to determine the age of all planets?
No, half life can only be used to determine the age of planets that have radioactive elements present in their rocks. This method is not effective for determining the age of gas giants like Jupiter or Saturn, which do not have solid surfaces.
5. How accurate is half life in determining the age of a planet?
The accuracy of half life in determining the age of a planet depends on the precision of the measurements and the assumption that the decay rate has remained constant over time. With advanced technology and multiple samples, scientists can achieve a high level of accuracy in estimating the age of a planet.
  • Classical Physics
