Harmonic Motion-Just need to make sure
  • Thread starter Thread starter jago-k1
    Harmonic
A mass of 100 g is undergoing simple harmonic motion with a period of 0.993 seconds, and the goal is to determine the spring constant. The relevant formula used is T = 2π(m/k)^(1/2). The calculations involve rearranging the formula to find k, resulting in k = (2π*m)/T^2. The user is seeking confirmation of their solution before finalizing the answer. The discussion emphasizes the importance of verifying calculations in physics problems.
jago-k1
A mass of 100 g is hanging from a spring and is set into simple harmonic motion. If the period of the pendulum is 0.993 s, what is the spring constant?
T=2pi(m/k)1/2
I just want to make sure its right before I plug in the answer. Thanks.
T^2 = 2pi *(m/k)
k*T^2 = 2pi * m
k = (2pi*m)/T^2 = .637 N
T^2 = 2pi *(m/k)
T^2 = 4(pi)^2*(m/k)
rl.bhat said:
T^2 = 2pi *(m/k)
T^2 = 4(pi)^2*(m/k)
kk, thanks. :)
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
