Harmonic Probability Homework Solution
The probability of finding a particle oscillating in simple harmonic motion between positions x and x+dx is defined by the equation P(x) = dx/(π(a² - x²)^(1/2)). This is derived from the relationship between displacement, velocity, and time, specifically using the equations x = a sin(wt) and v = aω cos(wt). The key to solving the problem involves normalizing the integral of the time spent in the interval, dt, which is directly related to the probability of locating the particle within that range.
  • Understanding of simple harmonic motion principles
  • Familiarity with calculus, particularly integrals
  • Knowledge of probability theory in physics
  • Basic understanding of trigonometric functions and their applications
  • Study the derivation of probability distributions in oscillatory systems
  • Learn about normalization of probability functions in physics
  • Explore the relationship between velocity and displacement in harmonic motion
  • Investigate the implications of time intervals in probability calculations
Students studying physics, particularly those focusing on mechanics and oscillatory motion, as well as educators looking for clear explanations of probability in harmonic systems.
poobar
A particle oscillates with simple harmonic motion along the x-axis with a displacement amplitude, a, and spends a time, dt, in moving from x to x+dx. Show that the probability of finding it between x and x+dx is given by P(x) = dx/(pi(a^2 - x^2)^1/2)
x = asin(wt)
v = wacos(wt)
I'm really kind of lost on how to begin this one. I know I have to set up some sort of integral involving the time it takes to go from x to x+dx which would be dt. I know that to get a probability function you've got to normalize the integral. If someone could point me in the right direction, it would be much appreciated.
P.S. I know there is another thread on this, but I started a new one because I don't really understand the other thread. Thanks.
You've got the right idea. You need an expression for dx in terms of dt, because dt is the measure of probability: the more time spent in that interval x and x+dx, the greater the probability of finding the particle at x.
You listed v = aw cos wt, but v = dx/dt. So this looks like a good starting point. Next thing to think about: if the particle spends time dt between x and dx, what probability does this correspond to? We know that within half a period, the particle has been through every possible location between -a and a only once, and then the motion repeats. The total probability of the particle being between -a and a within this half a period is 1, so what is the probability corresponding to the time interval dt?
So to summarise, begin with v = dx/dt, and use the fact that dt has a relation to probability, and perform a substitution along the way to get the right expression.
okay, so dx = awcos(wt)dt
also, the probability for dt will be 2 i think.
i believe i will need 1 = 2dt/T because there is a probability of two for the entire period since it goes through each position twice. then i make some substitutions. dt = dx/awcos(wt). i can pretty much see how i have to do this now. it makes a lot more sense now. thanks!
