Heat equation problem so confusing
104 replies · 11K views · last reply
JI567 said:
## \frac {1} {π} \ ## ( ## \frac {2n} {n^2-4} \ ##)
Yes. Nicely done.
so only when n = 1 my Bn will be the result of 2 ## \int_0^1 (cos(2πx) - \frac {1} {π^2} \ ##sin(πx)) * sin(nπx). When n = any other odd numbers except for 1 then Bn will be the result of 2 ## \int_0^1 (cos(2πx) \ ## sin(nπx). For n otherwise Bn = 0. Is this correct...?
So,
##B_1= -\frac{4}{3\pi} - \frac {1} {π^2} \ ##
##B_n=\frac {4} {π} \left(\frac {n} {n^2-4}\right)## for all odd n≥3
##B_n=0## for all even n.
Chet
JI567 said:
Okay like you suggested I have given the whole problem.
Tt = 4Txx + 4 sin(πx)
with 0 < x < 1, x is actually less than and equal too 0, greater than and equal too 1
Boundary is T(0,t) = T(1,t) = 0
Initial condition is T (x,0) = cos (2πx)
So I attempted to find the U(x,t) by U(x,0) = T(x,0) - T(x)
I found T(x) by boundary condition and got 1/π^2 * (sin(πx))
Chestermiller said:
Yes. Nicely done.So,
Chet
So for this heat equation, can the final solution be written like this
when n = 1
T(x,t) = (-## \frac {4} {3π} \ ## - ## \frac {1} {π^2} \ ##) ## \ e^{-4π^2t} \ ## sin(πx) + ## \frac {1} {π^2} \ ## sin(πx)
and for any odd n greater than or equal to 3
T(x,t) = ((## \frac {4} {π} \ ## ( ## \frac {n} {n^2-4} \ ##)) ## \ e^{-4n^2π^2t} \ ## sin(nπx) + ## \frac {1} {π^2} \ ## sin(πx)
and for all even n
T(x,t) = ## \frac {1} {π^2} \ ## sin(πx)
Here is the results you obtained rendered into a solution:
[tex]T(x,t)=\frac{sinπx}{π^2}-(\frac{4}{3\pi} + \frac {1} {π^2})e^{-4π^2t}sinπx+\frac{4}{π}\frac{3}{5}e^{-36π^2t}sin(3πx)+\frac{4}{π}\frac{5}{21}e^{-100π^2t}sin(5πx)+...[/tex]
Rearranging this in a little different way gives:
[tex]T(x,t)=\frac{1}{π^2}(1-e^{-4π^2t})sinπx+\frac{4}{π}\sum_{k=1}^∞\frac{(2k-1)e^{-4(2k-1)^2π^2t}}{(2k-1)^2-4}sin((2k-1)πx)[/tex]
Can you see how that works?
Chet
Chet
Oh I see...I added up each U(x,t) to the T(x) separately that's why and totally forgot about the summation thing for odd n. That makes sense. Cheers! However shouldn't the last equation be
[tex]T(x,t)=\frac{1}{π^2}(1-e^{-4π^2t}-\frac {4π} {3} e^{-4π^2t})sinπx+\frac{4}{π}\sum_{k=1}^∞\frac{(2k-1)e^{-4(2k-1)^2π^2t}}{(2k-1)^2-4}sin((2k-1)πx)[/tex]
No. Then the summation would have to be from k = 2. I purposely wrote it in this form so that the term outside the summation would represent the separate effect of the heat generation, and the summation would represent the separate effect of the initial condition.
Chet
Chet
Okay cheers. One question outside solving problems. How in actual engineering does wave equation and heat equation help? How do I use these lengthy solution of equations for like making machines or something.
Initial condition is T (x,0) = sin (2πx)
I found T(x) by boundary condition and got -1/π^2 * (sin(πx))
So then I wrote it like U(x,0)= - 1/π^2 * sin(πx) + sin(2πx) = B1 sin(πx) + B2sin(2πx) so B1 = -1/π^2 and B2 = 1 and Bn =0 for n otherwise
Can I then write the final solution for this heat equation as
T(x,t) = U(x,t) + T(x)
T(x,t) = ## \frac {1} {π^2} \ ## (1- ## \ e^{-4π^2t} \ ##) sin(πx)+ ## \ e^{-16π^2t} sin(2πx) \ ##
is this correct? please check...
No way. What happened to all the other terms in the summation? Plus, there should be no terms containing sin(2πx). Just write out the terms in the result I gave in post #94.
Chet
Chet
The one is post 94 was different initial condition which was cos(2πx). This is exactly the same question as of post 94 but the initial conditions in the previous post if you see is now sin(2πx). That's why the solution is different and thus the term with sin(2πx). Do you still think its wrong?
Are you saying that this is for a different problem that we haven't discussed before?
Chet
Chet
Yes different problem. But only thing different is the initial condition...
Then, the solution looks OK, but you didn't need to use Fourier Series to solve this.
Chet
Chet
This is the only way I was taught to solve inhomogeneous questions like these... like finding the Bn and then solving for U(x,t)...is the solution really correct though?
As best I can tell, yes.
Chet
