Solving Heat Pump Problem: 1/W = 1/(1-5/20)
To determine the work per joule leakage for maintaining a house temperature of 20 degrees Celsius with an underground temperature of 5 degrees Celsius, the relevant equation is Q/W = 1/(1-(Tc/Th)). The initial attempt incorrectly used Celsius instead of absolute temperatures, leading to a miscalculation of work. The correct approach involves converting the temperatures to Kelvin, which resolves the discrepancy in the expected answer. Ultimately, the correct work required is approximately 0.05 Joules, highlighting the importance of using absolute temperature in thermodynamic calculations. Understanding this concept is crucial for accurately solving heat pump problems.
phoenix133231
If the temperature underground is 5 degrees Celsius and you'd like to keep the house at 20 degrees Celsius, how much work per joule leakage must be done to maintain the house at that temperature?
Q/W = 1/(1-(Tc/Th))
I know this may be wrong... but since I needed to know the work "per joule" leakage, I assumed that Q = 1 Joule. Then, I plugged in the terms into the formula provided and ended up with the following:
1/W = 1/(1-5/20)
which gave me W = 4/3 Joules. I checked the back of the book and the answer ended up being 0.05 Joules.
Could someone please provide me some understanding to this problem, as well as a hint on how to start? Is the formula provided even useful?
Q/W = 1/(1-(Tc/Th))
1/W = 1/(1-5/20)
Consider if you need to use absolute temperatures - degK.
ice
LOL. I'm such a noob. That was exactly the problem. Thanks a lot!
