Help calculating moments for a small crane-like machine
  • Thread starter Thread starter chavan
    Machine Moments
The discussion revolves around calculating moments for a small portable crane designed to retrieve a 200 lb sediment grab from a depth of 50 meters on a boat. Participants suggest starting with static analysis to determine the crane's stability and load distribution. There is a request for sharing results, diagrams, and any concerns or unusual values encountered during the analysis. The focus is on ensuring the crane can safely handle the specified weight and depth. Effective calculations are crucial for the crane's design and operational safety.
chavan
building a small portable crane to be used on a small boat that will be used to retrieve a sediment grab (weight = 200lb) at a depth of 50m
Have you tried using static analysis as a starting point?
yes i have
So...any results? Diagrams? Concerns? Questions? Values that might be weird?
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
